- 18 Oct 2002
- Welsh Wales
I cannot get my Router software installed on Vista (BT Voyager 2091). I have a connection to the internet. How would I forward ports without my router software, is there a way?
Bony Maloney said:Web Interface?? If they are DD it should not be a problem (although p2p is showing me as firewalled0 I will check the port munber on Vista and route it via XP and see if indeed the setting is for the Router.
Thanks guysWill post back.
dirtydog said:You may need to change your IP settings in your TCP/IP properties, that's what I have to do when I reinstall Windows anyway; I use port forwarding with a router tooIf your router is like mine though, you won't need to tell the router anything new.
Bony Maloney said:I cannot get my Router software installed on Vista (BT Voyager 2091). I have a connection to the internet. How would I forward ports without my router software, is there a way?
The command window opens and closes in a nanno secondzen62619 said:Go to start > run > type ipconfig /all
look for the default gateway and type that ip in the browser, it should bring up your configuration page for your router.
ns400r said:Type cmd into the Run box to get a DOS prompt BEFORE running ipconfig /all
Bony Maloney said:Thanks done.. this is the message I get at the top of the page it opens: ../bin/busybox
No worrieszen62619 said:yeh sorry ment to do start > run > type cmd > press enter> type ipconfig /all > press enter ...
Sorry.
Will boot into Vista and post back, thanks for your helpZap said:THat's fine, what happens if you try typing the ip in the web browser in vista or another computer? Failing that you might need to do a factory reset on the router
