vista basic 32bit OEM , where can I get it ?
20 May 2010
World
Hi Folks,
I was wondering if someone can help me out I have to re-install a laptop
that has vista 32 bit Basic (OEM) on it , it has a valid windows sticker
so the key is not a problem , but getting media to re-install is.
Can anyone point me to a working download link to get the iso of it ?
Thanks
You could get a disk from ebay. I would expect the normal retail version to work but you may well have to do a manual telephone activation.
Where abouts in Norn Iron are ya lurkio? I can sort you out with an OEM unbranded disk and / or ISO that will work with a legit key
Thanks folks , I am going to try the links from more speed first , that will
be the easiest to test out
I tried using a dell vista 32 OEM home premium disk , but it would not accept the key :(
I had luck with a retail vista ultimate iso that I needed to use to install and license a vista business OEM key. I don't quite remember offhand but there was a file in the ISO that I had to modify which allowed me to choose which version of Vista I was installing at install time. The OEM key then licensed no bother.
I think ultimate is meant to be the best ISO to try get hold of (bar of course an actual vista basic ISO!) as it'll contain all the versions?
ei.cfg
Easiest to create a USB install drive with the ISO/DVD using Microsoft's own USB tool. After it's done, remove the ei.cfg file from /Sources (iirc)
lurkio
You can use any OEM disc on any OEM system, the only thing different is the key. Are you sure the key is not the problem, if so, then a quick call to Microsoft will sort that out.
Well I just tried mr speeds linked method and it does not work :(
It accepts the key and then errors saying that it cannot access Install.wim file
I checked the Install.wim file and it is 2G in size .... but only contains one file
not the loads that it is supposed to
Trying this right now
http://forums.anandtech.com/archive/index.php/t-2232457.html
To see if these download links are correct
Update:
I tried the method from the annatech link and it WORKS! :)
I have made both x86 and 64 bit version ISO's , tested the x86 one and it works great
Thanks for all the help guys, especially those offering me discs :)
