Hi,
Just built a new Vista based system, but im having problems when copying files from a CD to the Hard drive. It does the time calculation and begins copying but half way through it just stops and hangs. Tried different DVD Drives, Different CD's, copying different files, it always just hangs!
Any thoughts?
Will post full spec if needed.
Intel Core 2 Duo, Gigabyte 965P-DS3, 1Gb Ram
RESOLVED ISSUE : SOLUTION WAS TO RESET BIOS AND DELETE DRIVE FROM DEVICE MANAGER, LET WINDOWS REBOOT AND REFIND THINGS. NOT SURE WHY, BUT THIS IS WORTH A TRY INCASE YOU ARE HAVING THIS PROBLEM.
Any thoughts?
