Vista lag using wireless
29 Nov 2006
The Mo0n
Hi guys!
Using a fully updated version of vista 32bit here but every 60 secs it seems my ping spikes to 200ish ms and then settles back to w/e it was, Pretty annoying and I've not found a way around it yet:(
I have 2 other PC (With XP) using wireless playing the same server with me and there pings are stable, I'm pretty certain it is vista:mad:
I can't install XP on my laptop due to it having 2 hardrives so I can't install raid drivers since I don't have a floppy drive lol =/
Games in question are BF2/CSS/TF2
Any idea's?
Reply from 212.58.224.131: bytes=32 time=38ms TTL=120
Reply from 212.58.224.131: bytes=32 time=43ms TTL=120
Reply from 212.58.224.131: bytes=32 time=37ms TTL=120
Reply from 212.58.224.131: bytes=32 time=39ms TTL=120
Reply from 212.58.224.131: bytes=32 time=232ms TTL=120
Reply from 212.58.224.131: bytes=32 time=154ms TTL=120
Reply from 212.58.224.131: bytes=32 time=152ms TTL=120
Reply from 212.58.224.131: bytes=32 time=40ms TTL=120
Reply from 212.58.224.131: bytes=32 time=36ms TTL=120
Reply from 212.58.224.131: bytes=32 time=41ms TTL=120
Reply from 212.58.224.131: bytes=32 time=42ms TTL=120
Reply from 212.58.224.131: bytes=32 time=35ms TTL=120
Reply from 212.58.224.131: bytes=32 time=44ms TTL=120
Reply from 212.58.224.131: bytes=32 time=267ms TTL=120
Reply from 212.58.224.131: bytes=32 time=204ms TTL=120
