Vista on a 512MB system
Went round this afternoon and turned off indexing and set it back to classic view - speeded up slightly, but I'm not impressed with it. And to top it off her Lexmark printer wont work with Vista so she has to buy a new printer now too. If it was running XP the spec would be fine - literally this is used for browsing the web and typing letters in MS word. I'm tempted to chuck a dodgy copy of XP on it - at least it would run quickly and the printer would work.
I have no idea where the Vista system requirements are going for the 'average' user - seems like a con to get people to upgrade perfectly good hardware. Its even more of a system hog than my Powerbook, which i despise for similar reasons!
That 'perfectly good' hardware is in relation to a 6 year old Operating System though. It's Acer's fault for selling a system that isn't capable of running Vista properly.
firewallblocked said:
making it very likely the hard drive will have a much SHORTER life due to constant reading and writing from the cpu
there's no data to back that up
google did a massive hard drive test, testing low usage, no usage, high usage using thousands of drives and there was no pattern in the failure rates
512MB with Vista is pretty dire. Bung another 512MB stick in there, or ideally a 1GB stick.
