csmager said:And this is because you've turned UAC off...
marc2003 said:when setup gets stuck at the prompt above, browse to your temp folder and copy/paste the adobe reader setup folder to another location. now cancel the error prompt and you can run setup from the files you copied a minute ago.![]()
t31os said:You could try the alternative which is better imo.
Google 'Foxit'.... not sure if it works in Vista, as i'm not running it... worth a look though.
mcdermotx said:Its a little easier to just change the install program to WinXP2 compatibility and run as admin..
