Vista Problem???
Permabanned
21 May 2006
Newcastle
Can anybody tell me how to use the Aero thing and how to make the windows tilt like 3D :confused:
Any help would be great :)
Windows key + tab for the tilt? I may sound like an idiot which windows key and do you then use the mouse wheel?
Hold down the key on the left side of the keyboard, in between Ctrl + Alt, with the Windows logo on. Then whilst holding that down, press TAB. Each successive press on TAB will cycle through the windows.
Alternatively, instead of pressing TAB, roll the mouse wheel up/down. You can also use the mouse to point to the window you want. When you've chosen your desired window, let go of everything and it will come to the front.
Im trying to do that actually the Alt + Tab gives me the option on screen to switch between windows or Desktop but when i use the windows key + Tab all that happens is it highlights every clickable option on the web page as if i have no mouse. And as for that Aero thing i have a good Graphics card x800gto2 am i not supposed to see the desktop behind the window its just like a metallic blue
