Vista Questions
4 Jan 2007
Hello people
I use to have Windows XP , you could choose disk defragmenter volumes ie choose C or D . But with Vista you cannot choose which volume to disk defragmenter or can you ?
Also my other question is when you want to use a programme on Vista i get a pop up saying " Windows needs your permission to continue" can you disable this command ?
MRBARKER said:
Hello people
the user acount control is configurable (from user accounts in control panel) and the defrag can be scheduled or run now, you need to enable schedule, let it start up then click on run now.
I have sorted the account configurable
Still cannot locate choose disk defragmenter volumes ie choose C or D ?
disk defragmenter still does whole pc , i want it just to give me the option just defragmenter volumes C or D
If you just want to do one drive, then click start, run either open a command prompt or just type in "defrag c:" itll run off and do it for you.
Thanks , i am thinking that XP is a better OS and better to use
I think you need to run the command prompt as administrator to run defrag, which is easily done.
press your start button, type CMD into the search pane, you'll see cmd.exe appear at the top of the list, right click and run as administrator.
Then, as above, just defrag c: or defrag d: etc
For more info, you could (as I do) use defrag c: -v
or to just analyse, use defrag c: -a -v
V1N.
Just get a better defrag application - neither XP's nor Vista's is particularly good. Something like Perfectdisk is far better.
