Vista Tips !
20 Sep 2005
Wilderness of ESSEX
Hi,
can any one please tell me how I get the Title bar along the top of the window screen. ie, File, Edit, View, Tools etc
I am sure the option is buried some where in Vistaa control panel !
Mnay thanks
press 'alt' to show it temporarily.
or goto organize, "folder and search options", view tab. tick the option "always show menu". :)
I'll jump in. The new start menu search box includes Internet Explorer bookmarks in its search results. How can you make it include Firefox bookmarks?
I don't use Firefox, so I can't test this. But if you go into Control Panel > System and Maintenance > Indexing Options.
Then add the Firefox bookmarks folder (whereever they're stored) and they should show up.
won't work because firefox stores it's bookmarks in a single file. :)
Just done, thats has really helped.
What about the folder up button that XP had ?
Also in Internet Explorer to display the same file menu as for the Windows folders please ?
Many thanks
