vista ultimate 32bit => 64bit
IIRC you can download it through torrent legally assuming it dosent contain and cracks / keys or anything like that. just s'long as you use your key :)
but i could be wrong.
mind you i dont think anyone is gonna come knocking on your door either way
downloaded an image without cracks, used my key and worked fine.
too bad i had lots of problems with the programs i use everyday, and i reverted back to 32bit
This is the one area where Burnsy and myself don't agree with regards licenses - so I will add my own comment because until I can confirm or see proof otherwise I'm going to stick to my interpretation of the license.
From the very fact that you've only got Vista Ultimate 32bit on DVD means that what you've purchased is the OEM version.
The Retail version of Ultimate ships with both the 32bit & 64bit DVD's.
You made your choice at time of purchase - you decided on the 32bit version of the OS and that is all you are licensed to use.
The retail licenses allow you to move between 32bit & 64bit as and when however there is no indication that the OEM licenses allow you to do this.
You make your choice, which you made and now you've decided you actually want the 64bit version you need to buy a 64bit license.
The link indicated here:
http://www.microsoft.com/windows/products/windowsvista/editions/64bit.mspx
Is for people who bought a version of Windows Vista Retail so they can get a 64bit DVD because they are licensed to use it.
This is stated at the bottom of the page - notice it doesn't mention OEM versions because that isn't the case.
So as far as can be told from the license agreements you are stuck with the 32bit version of Vista until you buiy yourself a copy of the 64bit version.
Obviously this isn't the kind of post you want to read, so please don't "shoot the messenger".
I'm an IT Manager and I take licenses extremely seriously.
Until I can get something definitive to say differently it is a policy I stick to - there is no buying OEM Vista 32bit and then installing Vista 64bit - this requires two totally seperate licenses.
Before anyone posts about how you used the same key to install both 32bit & 64bit versions etc once again I need you to understand the difference between what is physically possible and what is legally possible.
I can go out, drink loads of beer, get stopped in my car and banned from the road for 12 months.
If I go out to my car the following day with my keys and attempt to drive the car anywhere there is nothing at all to physically stop me doing so.
However I would be breaking the law by doing so.
Anyway - I'll leave my post there.
Of course you won't want to really do as my post indicates as that would mean buying a new copy of Vista.
However remember that ignorance is not actually a defence with regards license agreements.
I'm not as convinced on that. I was one of the lucky few to win Vista Ultimate in that release promotion give-away they did. They give me a 32-bit disk (I assume every winner got the same), and wondering if I could upgrade to a 64-bit one I followed what every one else did and tried to order 64-bit media. Whereas standard OEM licenses allow you to order 64-bit media for your serial number, mine didn't, only 32-bit media was listed. I tested this with my other retail license and some OEM ones from work, and both offered either media.
Microsoft obviously lock some licenses down to whether you can use 64-bit or 32, but most don't have this limitation. Whether or not it would let me activate had I used some 64-bit media I don't know though.
