Are you a student? Surely there's something in the T&C's stating you need to be in full-time education to use it?PaulStat said:Well I have a genuine copy in my hands which i bought off of ebay, with all the cd's/auth code? So i'm confused![]()
Instead of paying £200 i've spent £50
riddlermarc said:Are you a student? Surely there's something in the T&C's stating you need to be in full-time education to use it?
The difference is the license you're buying.PaulStat said:I'm confused why is this so much cheaper? What's to stop someone who's not in unversity buying this product and installing it?
As far as i can tell it comes with all the CD's etc.
Mickey said:The difference is the license you're buying.
If you're not a student/using it for educational purposes (not sure if MS count self-learning as educational) then you may aswell have got a pirate copy and saved yourself the £50.
Using an educational copy for professional purposes is as good as having no license at all basically.
PaulStat said:Nope not a student
AFAIK its not illegal to buy educational coppies whoever you are.Gman said:Well then technically you are breaking the law then as you've purchased software under false information.
the fact you got it from ebay is probably why you got it without any sort of checks on your education claims.
PaulStat said:You make it sound like i've downloaded it from Kazaa, I have paid for this you know, albeit not the extortianate 200 quid
robmiller said:It's still not legit, though. Why didn't you just get the Express edition?
PaulStat said:I have a legit copy with certificates etc.
robmiller said:Err... having the physical license on paper does not make it a legal contract or remotely legitimate. I'm pretty sure in the educational EULA it states that you must be a member of an educational institution to use the educational edition.
Gman said:it may be a legit copy but the licence you've bought does not match yourself. Its like me phoning up for car insurance and telling them I've got a 3 wheeler reliant Robbin when I've really got a top of the range BMW. you'll get the insurance but the insurance docs won't match me or what I've got.
The issue is that the holograms and stuff just prove it's an MS CD, so it won't be full of viruses etc, ie it is the actual product.PaulStat said:tbh i didn't even know there was an express edition, i've bought the standard edition it has all the microsoft holograms etc.
it's boxed, has all the cd's (inc msdn), manuals. I really don't see what the issue is
Yes they are legal, that's not the issue.. you can buy exactly the same thing from a legit shop but still doesn't mean you are allowed to use it.PaulStat said:The guy I bought it of sells hundreds of items like this all legit copies. If they weren't he would have been found out by now
That's right, when you buy software it's not just the physical media but also the "right" to use the software - I can use a friends XP cd but use my own serial key and it would be technically okay. Buying the software entitles you to use it, if you are buying a package that's for students and you are not one then you are breaking the law, simple as that.Beansprout said:But that's not what you're buying. What you're buying is a license to use the software.
