- 1 Aug 2008
- UK
I've recently built a HTPC..
+ Motherboard - Gigabyte GA-H55M-UD2H Intel H55.
+ RAM - 4GB DDR3 - OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 (1333MHz) Low-Voltage Dual Channel (OCZ3G1333LV4GK) [OCZ3G1333LV4GK]
+ Using onboard sound and graphics
+ Windows 7 32bit
+ Processor - Intel Core i3 530 2.93GHz (Not Overclocked)
+ Connected to HDMI tv using the HDMI port.
I have transfered some DVDs to it so they can be played from the TV. The problem I am having is that VLC keeps freezing up the image after around 25mins, however the sound will either continue to run problem free in the background or the pc will completely lockup completely with a buzzing sound coming from the TV speakers. I have used VLC on a different PC before without the same problems. Does anyone know what would most likely be the cause of this problems.
+ Windows 7 32bit
I've settled on Splash Player now; it incorporates Nvidia PureVideo and is just lovely. I use MPC-HC for anything else.
