Hey,
I need to move my parents landline over to VOIP, I can get the Andrews and Arnold service and have their router with voip support - but after that I am clueless in terms of hardware needed.
* Can you use multiple (ethernet?) base stations for the same number? There is a long distance, too far for DECT, between one of the phone locations and the router so a single base station wouldn't work here.
* Can you run VOIP over wifi? Like is there wifi phones, or is ethernet basestation to DECT the way to go? Or handsets that plug directly into ethernet? I guess im not sure how the VOIP bit fits in for the handsets...
* Is there any kind of voicemail service, shared across all handsets? They currently use 1571 if there is something similar?
* Any phone/base recommendations that fit the above?
Thanks!
Thanks!
