- 25 Feb 2016
I'm looking to get voip for a business number. I'm considering A&A or VoIPphone (I've also seen spigate mentioned). The internet to the premises is pathetic with speed test of 12.8 down / 0.74 up. I have purchased a TP link MR600 router and with a three sim manage around 20 / 5-8.
I have a few questions if anyone would be kind enough to help?
I want to purchase a Grandstream HT802. Can anyone recommend the best place to purchase one? viophone sell them, so if I go with them that's easy, but A&A do not. Are the setting for A&A easy to obtain and input?
I want to use one of the ports on the HT802 to run a cable and replace my incoming connection at the master socket. The reason for this is having an auto dialler alarm linked to the socket. Is this easy to do and can anyone advise me what cable is required and how the wiring works?
I know viophone offer a mobile app but do A&A?
I spoke with voipphone, which raised a couple of issues.
The 2 ports on HT802 are considered as 2 users, so if I also want a softphone that will be 3, unless I can run both auto dialler and phone from 1 socket, which still means 2 users.
What I forgot to ask is can I mix plans and if I go for the £1.50 plan for all 3 and buy call recording, do I have to pay for it for each user I want it for?
A&A seem to have an odd setup where every user has their own phone number. I'm not bothered about the auto dialler, but if I am able to use desktop/mobile apps I want outgoing calls to all look like they are from the same number.
vopiphone also mentioned the auto dialler may be an issue and an adapter may be required and also went on about amps etc, at which point I went a bit cross-eyed.
