- 25 Feb 2016
Thanks.No wonder it's not working at 60 minute intervals. Mine is set to 30 seconds.
I've set Register Expiration: to 1 which is in minutes and is the lowest value I could use (unless I can use 0.5? Edit: can't 1 is lowest). The options for it are: (in minutes. default 1 hour, max 45 days).
If this is such a critical thing why is it set so high to begin with? Also is there a way to find out how quickly it stops working? If for instance it's every 45 seconds that means there will be 15 seconds per minute people can't phone in.
Ok That hasn't worked. I can call in just after updating but after a minute or so it fails again.
I have also found SIP OPTIONS/NOTIFY Keep Alive Interval: which is set to 30 seconds. I will have a play with lowering this.
EDIT: which I lowered to 10 and still have the "going to sleep" issue.
