- 22 Feb 2006
- Belfast
Hey 8 Pack
Im quite happy with my 4.6ghz turbo overclock as it is only using 1.28v under load and the temps are great. My question is, what should my voltage be when idle. My voltage is around 1.056 when idle. is this correct? If not, what can i do to make this decrease to something lower when Idle.
I read somewhere that this is quite high for an idle temp and should be around 0.96 or so.
any ideas?
Chris
any ideas?
Chris
Ram ratio set to auto. Is this correct or should it be set to 100:100
