Hi i have just done my first ever overclock from 3.4ghz to 4ghz on my new i5 2500k. just a quick worry i have though as the guide i am following seems to have a cpu voltage manual control and in my bios the same area says cpu offset and i have a + mode and a - mode which im not to sure on how to use.. i seem to be stable atm around 50 degrees c but the voltage read as you see below is higher than the guide said to set this to (guide says 1.12v give or take) i have an asus p8p67-m mATX mobo any information on how i may set my cpu voltage manually would be greatly appreciated also is the vore to high for 4ghz and is 50-55 degrees c idle hot for that oc? thanks.
