- 22 Dec 2010
- West Midlands
I finally got my VORON 2.4R2 3d printer kit delivered, wanted to have a go at building one for ages - anyone interested to see how I get on?
I am very pleased so far with the LDO quality, all the parts I've touched so far seem top-notch. Storing parts in the garage, the printer in my cabin, and use the granite island in the kitchen for assembly (while the wife is at workas i mentioned in sv08 forum.. interested.
LDO are regarded the best ones indeed.
i would suggest that you dedicate a proper space for the build
did you joined vorons discord?
I'm hoping the same - well done!I built my LDO Voron 2.4 last year and really enjoyed the process. Given I’m colour blind and have never touched electrics, I was exceptionally happy when I didn’t kill myself or burn the house down.
I prepared the linear rails by removing the shipping oil by soaking the rails in Isopropyl Alcohol before lubricating as per the LDO guide.
Yes a right pain, thought it would be easy - glad it's done nowGreasing these was the biggest pain in the arse I had during my build. I wish LDO had used the sleds(?) with captured bearings so I could have taken them off easily and greased them that way.
The 4 Z's, due to the low travel speed when printing, didn't have to be as "perfect" as the X & Y rails but I had to get them as good as they could be.
Yes a right pain, thought it would be easy - glad it's done now![]()
What size gap do you have at the bottom of the rails from the frame? They look low from your picture but I did leave the lower rubber bungs in a hole until I put the gantry and Z belts in.
I printed the parts myself on my Creality K1 using Hatchbox ABS, parts look pretty good (compared with some I've seen) - time will tell!looking good so far.
did you ordered it with printed parts or you will use PIF
