- 15 Nov 2002
I want to use a VPN in order to backup data on a server to a remote location. I've never really used VPN in this way before so could do with some advice.
The Server is running Server 2003 and the remote PC storing the backup will be running XP. What is the best method to achieve the VPN? Should I setup the remote PC as the VPN server and then connect to it with the Server?
