Hello
I'm looking in to the idea of renting a cheap VPS from OVH and then having Open vpn or softether installed and running it as a vpn server.
I would need different dedicated ip's in the uk and I see that OVH offer VPS geolocation for £1.69 each.
This is so I could attached each separate dedicated ip to a different computer ( virtual machine ) .
At the moment I use a paid VPN service dedicated ip's but certain site i need to access I can't and other times it can time out. Hence the reason i'm looking at this option .
Is this something that can be done if it isn't is there a way it can be please ?
Thank you for your time.
