- 11 May 2020
Hello All,
I want to build a new VR capable PC, I'm confused about the GPU and RAM clock speeds and what it means to best performance,
There are some conflicting points of view on Google so what I would like is clear definitive advice,
I wanted to get the AMD Ryzen 3900X 12 core 4.6Ghz processor.
Both the Vengeance and Dominator Corsair RAM state they're 'RYZEN OPTIMISED' is that just sales faff, should I go for the higher speed Viper steel RAM?
Will the following set up work and be good enough for the top VR games?
MSI MEG X570 UNIFY (AMD AM4) DDR4 X570 Chipset ...Stock Code MB-34Q-MS.
MSI Radeon RX 5700 XT Gaming X 8GB GDDR6 PCI-Ex...Stock Code GX-35S-MS.
Corsair Vengeance LPX Black 32GB (4x8GB)
32000...Stock Code MY-4CR-CS.
Corsair Dominator Platinum RGB 32GB (4x8GB) 36000...Stock Code MY-4BY-CS.
Patriot Viper Steel 32GB (4x8GB) DDR4 PC4-35200...Stock Code MY-103-PA.
Any advice or tips for building a VR PC would be greatly appreciated, I became hooked on VR after trying it a while ago, lockdown has given me time to research but I want to be sure of what I buy as I know it's going to be expensive,
Many thanks,
Pete.
Many thanks,
Pete.
