- 30 Jan 2014
ive read that if you have 2 3gb cards in crossfire then you would only be able to use 3gb ram, if so why does it when im playing bf4 show as much as 3.5 - 4gn ram being used????
i was wondering what was happening, strange old program. even shows it as gpu1 usage with nothing being used on gpu2.
is 2gb not a bit low for bf4 maxed
cheers matt i read that yesterday quite a good read so it is.
If you're talking about the OSD, it only shows GPU1 memory usage. If you want to see both, then you'll have to refer to the graphs.
