As promised, full specifications:
Case: Fractal Design Define XL Black
Motherboard - Supermicro H8DAi-2
CPUs - 2 x AMD Opteron 2419EE, Heatkiller Rev 3 blocks
RAM: 16GB (8 x 2GB) DDR2 ECC Registered 800MHz
Graphics card: MSI GTX 470 Twin Frozr, EK Nickel/Acetal full cover block and black backplate
NIC: Intel Pro/1000CT PCI-E
Sound card: Asus Xonar DS
Storage: 3 x Samsung F3 1TB, Samsung F4 2TB
PSU: OCZ ZX Series 850W
Fans: 6 x Zaward 140mm
Other watercooling: Bitspower 420mm radiator grille, XSPC 7/16" ID clear tubing, EK Multioption 150ml reservoir, Magicool slim 420mm radiator, Laing D5 pump with EK top, generic black nickel 1/2" fittings, 2 Bitspower 90 degree fittings.
I just want to say thanks again to rjkoneill, who helped me mod the case when the rad didn't quite fit with the hole I had cut, and helped me with the loop layout. Also thanks to the rest of the OcUK tech team for their help, advice and support.
The exterior of the case, showing the Bitspower rad grill on top. Excuse the messy cabling behind the PC. Oh, and rjk (and the rest of the tech team) - look under the system and you can just see the LOltrolley
Here's the interior.
Upper left, showing the 24 pin and 8 pin connectors, the rad, and rear exhaust fan.
The upper right, showing where my tubing goes into the radiator, as well as the 4 pin power connector. I do need to top my loop up a little, hence the air in the tube.
The lower half of the board, showing off my chipset fans hah. You'll probably see they are on reducer cables which is a little untidy, I might do something else with them to neaten it up but they'll do for now. They're still the loudest thing in my PC but not too bad, the chipsets do get very hot with such small heatsinks and I would replace them if I could.
To do: figure out why the system doesn't like my F4 2TB (access speeds are incredibly low) and resolve some freezing issues in games (yes, I game on it too as this is my main rig), possibly add RAID card, and buy SSD(s).
If anyone has questions about the build in general or would like more pictures of anything, just let me know and I'll be happy to answer. Apologies for the not amazing picture quality, the camera I'm using isn't great and nor is the lighting in my room.
