VTX3D ARRIVED AND INSTALLED PROBLEM
Fire up GPU-Z and then run Heaven with heavy settings in a window to monitor the speed your card is running at under 3D stressing. You can save to a .txt file from GPU-Z also.
I don't know if your card has the BIOS that overclocks dependant on the environment and is why I'm asking you to monitor while stressing your card in Heaven.
*Edit: Or what MOOGLEYS has suggested :).
