you also pay for better pcb quality (copper? layers?) and components.
They may well do. but i tell you what
This was my last GPU, look at all that marketing humph there about durability and double layered circuitry....
Excellent cooler, no question about that, but if you want to talk about the PCB, the apparently supper doper one on that one was junk, it was thin, flimsy and bent where the Memory IC's meet the cooler, it wasn't just mine, you look at all reviews they all have that slight kink in exactly the same place.
It was also a pig to overclock, instead of dropping the driver and recovering like its supposed to it would just BSOD my computer every single time.
By comparison the PCB on this Powercolor is twice the thickness, arrow straight and solid, it has never BSOD my computer and overclocking it is child's play in comparison.
Looking at the build quality, the Powercolor has better construction and a solid alloy shroud compared with the flimsy plastic one on the Gigabyte, and also has cleaner soldering, the printed circuitry is also thicker and more substantial, it has real definition on the PCB as opposed to being pretty delicate on the Gigabyte.
Also, AMD have a certain standard set for third parties in the components they are supposed to use, about a year a go AMD had a go at (coil whining) Sapphire for using sub par micro capacitors.
MSI, how long is that list of problems with their GPU's as a result of cost cutting?
The thing with the (establishment) is they often get to a point where they feel their reputation alone will sell their products, and so they look to cutting corners.
VTX / Powercolor... i know and knew before i bough it that they often don't have Hynix Memory IC's, often, as they are on mine they are Elpida, and invariably only clock to 1600, on the 7950's the clock to 1750, not 1900 like a lot of Hynix IC's, but having said that on the Gigabyte 7870 the Hynix IC's invariably only clock to 1500!
Mine has a HS on the Mosfets, the Gigabyte one didn't and the VRM's as a result got a lot warmer, and like the Gigabyte mine has full Alloy chokes and Japanese Solid state Cap's.......
I hear what your saying, but. It would seem in reality its not what you would expect. Powercolor and VTX need to prove themselves, Gigabyte don't and i can see far more corner gutting on them.
