'My 1.8 Celica with a whopping 140 horsepower doesn't throw me back in my seat when I put my foot down at 30mph in 4th, what is wrong OcUK?'
And how can you not tell if your clutch is slipping?
And does it really confuse you that pulling off in 4th or 5th makes you stall?
Been driving long?
[TW]Fox;15325407 said:For once I'm with dirtydog. There is nothing wrong with this car, it just isn't very powerful. It makes all its power higher up the rev range so of course in 4th at 40 you are out of the power band and the engine labours before it gets into the power band, causing this delay.
To avoid this, drop 2 gears and nail it. Then it'll move (Well, as much as it ever will).
From his description that the revs are rising without an increase in speed, it sounds like the clutch. If that is actually what is happening however
Replacing clutches is a bit of a performance on most cars really. You'll just need to ask around really!
VVTI just kicked in, y0
VVTI just didn't kick in, y0
