In my quest to find the best case for a new Watercooling setup, I've been advised to have a look at one of the Gigabyte Aurora cases.
The main requirement for this case is that I want to mount a 120.2 Rad with 4 fans in it, in a push pull configuration.
Out of all the cases I've looked at, the gigabyte is the only one that could fit dual 120mm fans side by side by default. Although this is at the back of the case, I can always reverse the airflow through the case (pretty much as I have it in my current setup).
Is this case any good ? Thoughts, questions and comments welcome.
