- 25 Mar 2006
- Thornbury
ok i have done a bit of research and i cant get anywhere with this. i have a laptop and a destop pc both with w7 installed, i can share files using the homegroup and access each pc's files and documents that homegriup allows.
i cant acces drives or folders using windows explorer thru the network folder, i have the pcs in the same workgroup, i set folder sharing preperties to sharing, eset security is set to allow folder sharing, i have disabled password protected sharing, i have set the user account on each pc to the same name.
any suggestions what to try or check next
why is it so hard what was wrong with the network wizard in xp it always worked for me
