Wait for Kaby Lake?
2 Oct 2009
Scotland
So I've been out of the loop for a while. By the end of the year I'm looking to build a new high end gaming PC, as future proofed as I can make it.
I had figured I would build it around a Sky Lake CPU, but a little research tells me that Kaby Lake might be released in Q3.
Do you guys think it is worth waiting for it? Or would you suggest something else?
Zen's apparently due around then too, so I say it's worth waiting to see which CPU does better. Intel's CPU performance hasn't improved much recently due to a lack of competition.
Considering your current CPU, which is still a very respectable performer, I'd say wait. If you were using a Core 2 Duo or something it might be worth upgrading now, but you could easily just drop a new GPU in there for a nice performance bump until Kaby Lake/Zen arrive.
I don't think Skylake will become redundant anytime soon, but then neither will your i7 920. I would just go with whatever is cost effective at the time you build.
Kabylake wont likely be much of an upgrade from skylake. It will be another 4c8t CPU with cannonkake being the next CPU lineup.
Cannonlake will be the first set of consumer cpu's with a 6+ core top end cpu.
You want 'future proofing' best to see if Zen is any good (caution AMD have of late promised much but rather undelivered) or buy a broadwell-e setup.
Alternatively as a cheap option buy a Xeon and drop that in your board
It's not that far off so I would wait to see how good it is, even if it's that same number of cores and frequency there will be improvements in the architecture with things like instructions per clock.
Its a CPU on the same 14nm process with the same core design with a few tweaks. Some versions may come with the 'Iris Pro' L4 cache that will speed things along. But ipc and overclocking potential will be very similar to skylake.
Judging by the 5775C, overclocking will be very hampered if it has Iris Pro and L4 cache.
Kaby lake Edram might be useful?
CPU increases are slowing to a crawl but I'd forget about quad core and save for Broadwell-E. That will last forever at this rate...six cores plus HT
I'm quite happy with my CPU for now
If you don't need the onboard graphics I'd be temped to go with the e-range which is what I'm going to do. I did plan originally to upgrade to Haswell-E but I had no need for it at the time so held off and kept the 3770K which still performs well today
Thanks for the responses!
I'm planning on getting together a 4K gaming rig. Likely a GTX1080 or 2 (I won't have patience for the inevitable 1080Ti). It felt to me like the i7 920 might be getting a bit long in the tooth for just now. However, you guys seem to think there is some life in it?
I presume 4K gaming is all GPU based, will an 8 year old CPU be the bottleneck I think it will be, or will it cope?
And to summarise:
Broadwell-E is coming v soon and is likely the last X99 but should last a long time due to the number of cores?
Sky Lake is Z170 with Kaby Lake succeeding it, likely a small upgrade (how many cores?)
Cannon Lake will be a different architecture (i.e. needing a different mobo chipset?).
I've never really considered an AMD CPU, should I?
You would get more future-proofing from Broadwell-E... get a 6, 8 or 10 core CPU as multi-threading for more than 4 cores is just starting to come into its own in gaming and that will only increase / improve.
The CPU you have at the minute will affect both your minimum and max frame rates at 4k but it will have the biggest impact on your minimum frame rates which is where you will notice it the most.
Skylake makes a good improvement over Broadwell for minimums... let alone older CPUs.
I noticed the performance improvement going from 5820k -> 6700k
Not really, the cores generally run a bit hotter than the iGPU... so they tend to run a bit warmer.
The 6700k is rated at 95W TDP (max heat disspiation)
The 5820k is rated at 140W TDP
It depends what you're doing with them, but the 6/8 core CPUs tend to run a bit warmer than the 4 core CPUs.
There's not a huge amount in it though really as the E-series CPUs are larger, so they are able to dissipate that heat over a larger area and have that larger area in contact with the CPU cooler... so they might put out more heat, but at the same time they are easier to cool.
Why is it a concern? A normal cooler works fine on both really.
With a Noctua D15 - I have my 5820k running cool and quiet at 4.5GHz.
No such thing as future proof mate as far as gaming is concerned, however at the rate Intel are going any modern CPU will last you a decade minimum. Kabylake will likely bring native USB 3.1 to the motherboards, that's about it. Won't be any different to Skylake.
I would wait for Skylake-E, it won't be that far off considering the amount of time between Broadwell and Skylake.
Skylake-E isn't going to show (if at all) any time soon, Q2 2017 at the absolute earliest.
Kabylake will be backwards compatible with the Z170 (and other '100' series chipsets) but it will also release with the new '200' series chipset (Union Point) which you will want to buy to get the most from Kaby Lake
That's new to me. Interesting.
I'm in no rush to get the new rig together, I'm sure I can wait until at least Computex and see if Intel releases any more information then.
Until then I think I'm more tempted by Broadwell-E than Sky Lake right now.
Started a new thread... but as predicted Kabylake looks to be a very minor upgrade from Skylake... main benefits will be seen from going from the Z170 chipset to a '200' series chipset (Z270?). But these benefits will be in IO not performance for the most - more PCI-E lanes, Optane, native USB 3.1 etc
As predicted not looking like the 7700K is going to offer much over the 6700K....
4c8t
Not looking like stock clocks going to much faster (may even be slower!)
Not looking like it will have the 'Iris Pro' eDram L4 memory
Minor improvements to the same design as Skylake on the same 14nm process
Improved iGPU!
Similar/ possible the same TDP
Likely similar (or worse?) overclocking
The only tangible benefits from the next Consumer lineup refresh will likely come from the new '200' series chipset (Union Point) with more PCI-E lanes, OP\optane support etc...
Otherwise likely nothing to see here for exisiting Z170 owners running 6700K's.....
