- 7 Jul 2008
- Newcastle upon Tyne
So i decided, when the RTX 2080ti came out not to upgrade from my GTX 1080ti as I felt the performance increase was not worth the price.
however i am now considering the RTX 3090 as the rumours look favourable.
my current pc is showing its age and just looking at what will be best to upgrade is going the 3090 route.
Current mobo and cpu is x99 and i7-5820, 32gb ram but cant remember the spec
i would have thought upgrading mobo, cpu, ram and probably the power supply will be in order.
PC is used for sim games only, Assetto Corsa Competition, rFactor 2, Project Cars 2 and a few others. I am running triple monitors, 32” 1440p, 144hz (main reason for wanting the 3090)
So do i stay with intel of go amd. Whichever route which spec Intel/AMD should i be looking at. Again depending on CPU what ram should i be looking at
