My method is 4 screws
2 below to support the router and 1 either side nearer the top with a long bag tie across
I don't think that the router's power cable partially wrapped around the black network cable qualifies as PoE.![]()
I'm not quite following your setup apart from what looks like power over ethernet? What equipment do you have connected?
@andy_mk3
Good to know some manufacturers have the common sense to provide a couple of mounting holes, bravo for ASUS.
Also, don't the router's instructions suggest that the outer antennas should be at 45 degrees for best performance? Or was that tried and found to be incorrect in this situation?
Lmao! The Openreach modem is connected to the ASUS router, then I have a cable going to the box on the wall which leads to an 8-port switch in my bedroom, everything else is wireless.
I'm not following why thats so hilarious. O_o
