Just received my Thermalright Ultra 120 this morning in the post from America.
I started to attempt to fit the heatsink to my motherboard (ASRock Dual SATA-II) and then realised that my cpu retention module wasn't screwed in from the front to the backplate, in which case i thought ok, i will just take out the motherboard as it must be fastened to the backplate from the back.
When I had dismantled my pc (PSU Out, all my tidy wiring moved, motherboard unscrewed) I then realised that the retention module was just clipped into the mtherboard and I didn't have a backplate at all
So, no problem, I will just pop online and If i get it ordered today will be with me tomorrow so I can overclock some more on the weekend.
The only place I could find them was an American Retailer, with delivery time 3-7 working days
So the pc is now in bits until it arrives as I can't be bothered to put it al back together when the motherboard will have to come out next week anyway.
Luckily I have a laptop I can use!
Apparantly most ASRock and Gigabyte motherboards don't have a backplate so be warned if you are buying a Thermalright Heatsink!
Probably a lot cheaper now though. Never really liked this board tbh. I miss my old socket A Epox 8RDA+. That was a cheap(ish) board but so much better than this one.
Last one i had was a 865PE board i forget the name of that died in 2 weeks, replaced with an IC7 and shes still tickin 24/7.
