washer not drying
Permabanned
21 Mar 2013
hey , my washing machine is not drying well clothes.
only if I put big pieces, for example pillows or carpets.
what should I do? call service?
You need to climb in yourself it'll dry properly then. Why does the Italian national anthem say something about a vespa? :confused:
did you try cleaning the filter? if its blocked with fluff it wont be very efficient.
the heating element might have blown though does it feel hot in the drum after it's been on fore awhile?
How do people live without basic trouble shooting skills and general knowledge?
If you're referring to a washer/dryer than i have previously found you can only dry roughly half the amount that you can wash at one time.
Tried emptying the condenser tray? My sister thought you actually had to fill this with water - then wondered why her washer/dryer took forever to dry anything...
