- 23 Dec 2009
- RG8 9
Afternoon,
I have just moved into my new house and everything is great, but the waste hose on my machine now does not reach the waste pipe. For some reason this house has the attachment just underneath the sink, when before it was behind the machine. I cannot drill any shortcut holes through the work unit, so need to either replace the hose with a longer one, or extend the current one. Annoying thing is that it is only about 10cm too short.
What is the easiest thing to do? I have looked at hose extensions but they are all far too long. Am I best off just replacing the hose with a brand new one and if so, how easy is it likely to be?
As the moment I can only use the machine whilst it is pulled out and the waste hose it taped to the draining board and goes into the sink.
Cheers.
Cheers.
