Washing machine problem
18 Oct 2002
My washing machine will only work when empty :(
At first i thought brushes but it doesn't even fill, if i start it locks door and does nothing.
Any ideas before I buy a new one? (Its Bosch WFF2001)
Got the brushes out while having a poke around, look pretty worn but still look ok or am i wrong?
Well they look quite worn, less than a third left.
New ones can be had for £3.37 from a reputable seller on the forest and that includes delivery !
Thank you, saw some for 7 quid elsewhere but for that much why not
Swapped brushes still the same. Works perfect empty stick clothes in won't do anything.
New washer time i think :(
It's old decided to give up on it.
Got a Bosch WAE28167GB to replace it.
Edit: even with just a single towel would not work but fine when empty
Define work, are you saying there is no motor action when you have anything in the machine?
It did nothing, i mean nothing.
When empty it fills first before motor kicks in.
If had even a single towel in it just did nothing then came up with error lights like it wouldn't drain. But it was empty no water in it!
