Washing machine problem
18 Oct 2002
My washing machine will only work when empty :(
At first i thought brushes but it doesn't even fill, if i start it locks door and does nothing.
Any ideas before I buy a new one? (Its Bosch WFF2001)
How old is it? If quite old i would buy a new one. No need to get your head in a spin over it! lol
Yeah an old one can be quite a drain. Endlessly going round a cycle of breaking and repairs. Leaves you feeling washed out with your head in a spin.
Got the brushes out while having a poke around, look pretty worn but still look ok or am i wrong?
At first i thought bushes but it doesn't even fill, if i start it locks door and does nothing.
Its at least 15/16 years old. I sold a fair few of that particular model in the late 90's. Built like a Tank (German made Boschs were & if you can still get them are today I think) I would be very surprised that new spare parts would be still available, Bosch used to keep spare parts for DA's for 10 years, dunno if that's still the case though.
Like for like replacement won't be cheap.
OldCoals will be along sooner or later to recommend an LG, :p
Well they look quite worn, less than a third left.
New ones can be had for £3.37 from a reputable seller on the forest and that includes delivery !
Thank you, saw some for 7 quid elsewhere but for that much why not
Swapped brushes still the same. Works perfect empty stick clothes in won't do anything.
New washer time i think :(
It's old decided to give up on it.
Got a Bosch WAE28167GB to replace it.
Edit: even with just a single towel would not work but fine when empty
Define work, are you saying there is no motor action when you have anything in the machine?
It did nothing, i mean nothing.
When empty it fills first before motor kicks in.
If had even a single towel in it just did nothing then came up with error lights like it wouldn't drain. But it was empty no water in it!
