Washing Machine Water Feed Pipe Fitting
20 Oct 2002
Derby
Hi all,
I have a new washing machine being delivered on Friday. I believe that my old one was hot and cold feed so I want to cap off the hot water feed pipe after turning off the tap/valve to doubly make sure that it wont leak. Are the pipes a standard size/fitting? Just want to make sure so I can order a cap/stopper.
Thanks
Good practice to fully cap it off.
If you are lazy like me and just turn off the hot tap feed near the washing machine you will eventually make a small swimming pool in the kitchen.
