- 22 Jun 2015
Leave the rear as exhaust and swap the bottom rad to intake. If you have it as a exhaust the warm air is only going to be sucked back in by the psu and front fans.
Good luck!
Lookin at your diagram,would you not be better swapping the top rad round,so the fittings are on the righthand side rather than the left,for a cleaner look with your tubing?
also, why ram blocks? (they dont add much performance-wise, and cooling-wise. ie just a waste of money)
