Had a small leak near my drain port at the bottom of the pc so drained the system and fitted new o ring.
Re filled the loop and spent quite a while jiggling the case about to remove air from the loop as before.
Started pc up and the flow rate seems to have dropped from 0.7 to 0.4 gal/min?
Any ideas why this would be the case? not changed any loop order or anything, no sludge etc in the loop?
Reading the flow via a high flow sensor and aquero 6lt reported rpm of pump is 4823
