water changed colour
24 Jan 2008
By Coffee cup...
Hi,
Just noticed that water in my loop is slightly changing colour to blue...
what can it be ? why is it happening ?
I feel like a cleaning needs to be done to it soon...
Ideas?
Thanks
what fluid are you using? just water? how long has your loop been running?
a change of colour could be anything from some kind of reaction going on with a block, leaching from the tubing, something in the fluid breaking down...
but yes, a change of colour indicates something is going on in their that you might not want, so yes a clean and replace of fluid would probably be a good idea
just water,
tubes are transparent...
running almost a year - but water was topped up as I needed to empty loop a bit when I was adjusting waterblock on GPU.
seems like need to change it in next few weeks :)
thanks
water was definitely blue! no idea why...opened GPU block as it was replaced and looks almost as new inside..
