Water chiller
best off going over to xs forums they have a dedicated waterchiller forum so they should be able to help better.
in general it all depends on how much heat it can remove, if its only as pwerful as a fridge then its probably gonna burn out quite quickly, also depends on what your target temp> The experts are over at xs though.
What temps are you looking to get, as the lower the temperature the performance will drop.
