- 9 Jan 2013
Stacked water servers build log
Yes but they have a considerably larger surface area to radiate heat from compared to a traditional air cooling heat sink so it can radiate heat more effectively even if the temperature increasesHow is it going to help in the event of AC failure? The radiators are all inside the cases and rely on the ambient air temperature for cooling.
So it's all in the design then, excellent. It must have required slightly more planning compared to a normal loop then to get it past the boss, especially with the setup to ensure maximum uptime with little/no down timeThanks dude much appreciated, one case contains rads pumps and res, if there would be a leak it would be from that case this case will stay at the bottom of the rack with holes underneath to drop into a container, the qdc's will help during maintance as I have put together a moduler designed rad pump and res that will plug to a socket and join in seconds so no downtime during maintenance or disaster, dual d5 pumps in case of pump failure and a spare pump always sitting on our modular unit.
Some people sit and wait for 20-30 minutes for their profile to load. As far as i can tell, its a full gigabit network, thats what the connection reports in windows so that interface should not be the problem.
