water coolers please look
5 Jul 2009
DONcaster
would this work to cool an overclocked q6600 and a 5850
Best to res/pump cpu gpu rad then back to res/pump but your going to need a larger rad at least a 360 or 480 to cool those items. The Typhoon III res/pump would give you enough pumping power for that lot and with the option to dual loop. Google the Typhoon III for more info.
Wouldn't necessarily go for a pump/res combo myself, better of have a seperate pump and res imo. However the loop order is fine, the only thing that matters is that if you go for a seperate pump/res, then the outlet of the res must go to the inlet of the pump. The order of components to be cooled is pretty insignificant there is about a delta of 1 degrees c between having the gpu first or cpu first or rad before cpu etc etc.
Also you are fine with a 120x2 and 120x 1 for your rads, I used to cool a q6700 @ 3.53 ghz, the northbridge and an 8800gtx with a 120 x2 with no issues.
In fact I now cool a i7 860 at 3.65ghz and a gtx 275 on on a 120x2 and everything is fine.
Some more info on the actual parts your thinking of using for the loop would be helpful :p
As Dazzerd says, you should be fine for rads there. Im running an i5 at 4.2GHz and a slightly overclocked GTX275 using a single 120 and 120x2 rads. CPU doesnt hit 70 so you should be fine.
As others have noted, you may need to think about the pump/res. If you are considering a bayres and pump it probably wont be very good in that loop, the pumps arent very powerful and will struggle to push the water round so many parts in the loop. You'd be better off with a Laing DDC and res top. The 10W version should be fine but you could always get the 18W one if you plan to expand the loop in the future.
Rubbish. I am cooling my 4.6Ghz q9650 and my 1100/1300 5850 with one dual rad and gpu temps max at 40C and cpu is fine as well (can't remember temps at work sorry)
Before that it cooled my q6600 and gtx260 216 fine as well (max temp on the q6600 was 70C and gpu was 43C when I had 1.55v vcore and running at 3.85Ghz)
My radiator isn't the best either only being 30mm thick but I have got a good pump with the Swiftech d5.
I agree with Greebo. It's a common misconception that huge rads are required to water-cool these days and the fact is that the heatloads today are not much different from when we used heatercores. Rads have really developed over the last few years and some of the 240mm rads are extremely efficient.
Shouldn't the pump be the lowest part of the loop? That's what I was told once.
No. it doesn't matter where in the loop it is. More convenient to have it shortly after the reservoir.
Nah, pump should be the highest. Then it can use gravity to push it down.
When you so plainly don't know what you're talking about, stay quiet. There's always a risk someone will follow your advice.
Otherwise agree with the above. What fans are you running on the 30mm radiator Greebo?
I did not see the 240 rad in that diagram on my phone. I'm suprized that a 240 rad could handle the heat from that quad and gpu but as you said most likely the efficient pump your using is good.
Nothing wrong with res bay pumps, have a look at skinnee labs for the figures of the Typhoon III which uses a D5/MCP655 pump and you can use two loops of thar res without the need for restricting splitters.
Used to have 4 xilence fans on push pull with the q6600 and gtx260.
I am now the proud owner of two 38mm San Ace monsters!
I have modded them with resistors so they only get 10v max and have them on a fan controller as well.
I found that 12v was just overkill and didn't really add anything to the cooling performance. Now that they run at 10v max, lowest setting on my fan controller (4v) bearly has them turning (silent) but good enough for surfing like I am now.
Whack them to third speed for gaming keeps everything cool.
Put them on 10v for benchmarking when at 4.9Ghz etc (earphones required!)
The secret to succesful watercooling is matching your components.
By this I mean that some pumps suit high restrictive loops and others suit low restrictive loops.
I went for low restriction and have a low restrive cpu/gpu block, radiator and a high flow rate pump plus 7/16" tubing.
Put this with a high fin per inch radiator and two high pressure fans and I have a very good performing system.
As I type this (and play 3d poker) at 4.6Ghz cpu and my fans ticking over my cpu temps are 40C and my gpu is 35C (1050/1300)
People may pick a high restrive cpu block based on a good review and then match it to a low pressure pump and high restrictive 360/480 radiator with the wrong type of fans attached to it and they might have worse performnce than me.
Do your homework and match your components and you will have a better watercooling setup and save money.
San ace fans are beautiful. I have one here, going to sandwich it between two 120mm radiators. Different sound quality to my scythes, though not very subtle at 12V. I'm considering using a resistor my zalman fans came with but am concerned that I'll just burn it out (warm after a couple of seconds), these things draw more current than it expected. How hot do the resistors on yours get?
Some people pick a restrictive cpu block, and lots of small rather than one big radiator, then try to cool everything on the board. This is not recommended :(
Never felt the resistors so I wouldn't know!
I know what you mean about how many amps the San Ace draw. All I can say is that the resistors have being fine for the last 6 months+
Ah, that's enough of a recommendation. I'll dig out one of the molex to 3 pin connectors, wire in the resistor and hope for the best. Cheers
