Hi All
To cut down on noise and to make my PC a litle bit cooler I'm considering upgrading to a liquid cooling system. My current specs are:
Super Flower SF-750F14MG Power Supply
Gigabyte GA-MA770T -UDP3 Mother Board
AMD Phenom II X4 965 CPU 3.4GHz
AMD Radeon HD 7900 Display Card
8GB Corsair Dominator RAM
SSD 250GB I think.
I've been using the stock CPU fan since I built my little gaming PC and as you'll see from the pictures below I have used Xilence case fans added to the front panel case fan. The system is not running overly hot but the CPU fan is a noisy as hell so that's the main reason for my wanting to go over to liquid cooling. I'm stuck playing Star Wars Battlefront 2 at the moment and my partner can hear the PC fan's downstairs in the living room hehe.
There's a few pictures below of my Sharkoon case with all the internals on show so what's your best advice?
I'm not skint but I do have to be realistic on budget, will I be able to get a solution for less than £50 ?
Will it be quieter?
Feel free to pass on any advice or ideas, even if you think I should stick to a standard fan configuration.
Thanks in advance.
Trebz
SSD 250GB I think.
Will it be quieter?
Thanks in advance.
Trebz
