Water cooling advice
10 Apr 2015
airdrie, scotland
Hello
Hoping some helpful guys in here can recommend a decent cpu water block, res and pump and appropriate rads. Will be cooling a ryzen 1600 only atm
Last time I went custom I used the rubber type hosing however quite fancy going rigid route this time.
Currently have ryzen 1600, Asus prime x370 pro and soon to be using a be quiet 800 case
TIA
Basic loop for a single CPU ;
Product
EK Water Blocks EK-HD PETG Clear Tube 12/10mm 500mm (2pcs)
Stock Code WC-865-EK
2
£4.99*
£9.98*
EK Water Blocks EK-HDC Fitting 12mm G1/4 - Nickel
Stock Code WC-586-EK
6
£4.99*
£29.94*
EK Water Blocks EK-XRES 140 Revo D5 PWM (incl. pump)
Stock Code WC-886-EK
1
£115.99*
EK Water Blocks EK-Supremacy EVO AMD/AM4 - Nickel
Stock Code WC-9E5-EK
1
£59.99*
EK Water Blocks EK-CoolStream PE 240 (Dual)
Stock Code WC-487-EK
1
£54.95*
Mayhems X1 Clear Premixed Watercooling Fluid 1L
Stock Code WC-035-MH
1
£7.99*
I would also recommend a drainage port set-up which will add approx. £35 to the above
For Hardline you might want to invest in a decent heatgun, and / or bending mandrels.
Cheers for reply looks good so far, quick question the case has 2 x140mm BeQuiet silent wings fans installed would I he better going for a 280 rad and if so are those fans OK to use or would I be better of with dif fans?
Yes, use those fans and swap a 280mm radiator in
