Water cooling being quieter
Quieter depends on your point of view. a lot of air coolers have hig cfm fans which are usually quite high in db too. Good radiators only need low cfm fans to operate well and as such the noise is kept down.
I have 9 x 120mm yate-loons in my rig which run @ 7v and are near silent.
It depends on what you want the cooling set up to do though.
If you just want a quiet system with a timid overclock you can use low cfm fans.
If you want high performance cooling for a big overclock you need high cfm fans.
