Water Cooling Help
16 Dec 2009
Bolton
Hi I'm currently working on a water cooling build. It will be going inside a Coolermaster Cosmos S and the CPU block I have purchased "Impulse due to cheapness" is this.
http://www.zalman.co.kr/ENG/product/Product_Read.asp?idx=342
Now to be perfectly honest I'm slowly gathering the comonents to Water cool my PC other the following month so I'm hoping to start learning a lot more about water cooling. As of now I know absoloutely nothing other than that I have a CPU block I need a specific size tubing to fit it which will also need to go with a specific size pump/reservoir/radiator etc.
I'm hoping someone could enlighten me to some pumps and tubing which would go great with this. Now I dont want to be spending hundereds of pounds over some of this equipment I'm looking for quality cheap products. :)
Anyway to get to the point can someone fire a few recomendation links at me which will go with this CPU block etc.
Remeber I want this water cooling project to be completely internal no external reservoir etc.
Thanks for reading :)
Aluminium cover eeek.
What exactly are you planning on water cooling? just the CPU?
As a rule of thumb, watercooling shouldn't be done cheaply :)
CPU, GPU and possibly North and Southbridge. Not sure if I can find a supporting block for my mobo. So just CPU and GPU for now but dont bother finding a block for GPU. I can handel that :D
Also whats with the "eek"? Something wrong with Aluminium cover?
And screw going cheap I'll find the parts cheap just blast me some quality stuff that will fit :)
i believe hes refering to the mixture of metal elemets that you will be using which i think can possibly cause corrosion in the loop from what ive researched into for my proposed water rig. but dont take my word fully :)
Yep, mixing metals is a bit of a no-no with watercooling as said above corrosion can be a problem, you can get corrosion blocker additives but I would rather elimate that issue to begin with rather than deal with it later.
I would recommend a a good quality thick triple rad for your setup, XSPC, Black Ice and Thermochill all make good ones for this, I have only personally used Thermochills myself and never had an issue with them at all.
Pump wise a 10w DDC would be ideal for a CPU/GPU loop though i'm unsure how restrictive that block is, GPU blocks are quite restrictive as well so may also be looking towards getting a 18w DDC for the extra flow rate (which a high resistive block would prefer and imagine that block to be). You can also get a res top for either of those pumps so that saves buying a seperate one. You WILL need a 18w for sure if adding anything else to the loop
Tubing is down to preference really as very little difference between the sizes, 7/16 is a popular choice around here.
