Water cooling kit or DIY?
12 Jul 2008
Hello
I need help with water cooling.
I wolud like to cool a Q6600 on a P35-DQ6 F7. 4GB ram
I also want to cool my 2 3870 x2 cards and my be hard drives but i am not sure with them.
Can someone recommend me a kit or if not the parts to build a water system. looking for some expert advice. As i dont have a clue about water system i dont know whats the best to buy.
Cheers
What do you hope to get out of watercooling? What is your budget? Internal/External? Do you mind modding your case?
What do i hope for, well a cooler system for one and possbile a quiter system if I can. internal would be my perfered option thow.
as for budget well dont really have one to be honest.
As for modding a case bring it on something for me to get my hands on.
So what have you got in mind, My case is a soho file server viewty by Antec, but i dont mind looking at another case really. Really dont want a case the size of a small country but smiler sort of size to the one a have got, the antec 1200 looks nice and the lan li ones do look good as well.
what advice to you offer?
Hello
Cheers
I don't know of a kit that will cool that lot properly! Q6600 and 2 3870X2s will put out 400 Watts of heat- and that's assuming the Q6600 is at stock:eek:
Unless you want very high performance (=loud) fans you will probably need 2 radiators, say a 120.2 (or maybe a 160.1) for the CPU and at least a 120.2 (but more likely a 120.3) for the graphics cards. I wouldn't bother with the hard drives TBH
Are you going watercooling for quiet or performance?
quiet really.
hhhhmmm well the q6600 is on a Scythe Mine Rev-B Socket,
so i would need to get 2 radiators one for cpu and the other for graphics. or is it just better to cool the CPU and leave the graphics alone.
really want a quite system, or do i cool the graphics cards and leave the cpu on the scythe. would i get a better benefit doing it like that?
quiet really.
Well you'd save money if you just water cooled the CPU! Full cover water blocks for the graphics cards are not cheap
http://www.overclockers.co.uk/showp...35&name=EK 3870 X2 Full Cover VGA Water Block
You could watercool the graphics cards with 2 of these per card
http://www.overclockers.co.uk/showp...bcat=1035&name=Swiftech MCW60R VGA Waterblock
plus ram and mosfet heatsinks. That wouldn't save you much money, but they would be transferable to e.g 4870X2;)
ok
so lets say, i want to cool the CPU and one of the 3870 x2 (the other one will be brought at somepoint)
lets say, i brought 2 of the full blocks for the graphics and want to do the CPU. what kit do i need to buy or what parts? sounds like a diy kit
i i buy a cpu block (which one is the best?)
i got the to gpu blocks.
what else do i need to get to complete the system.
would this do the job?
http://www.overclockers.co.uk/showproduct.php?prodid=WC-021-SW
and them replace the VGA block with the 3870 x2
thanks for your advice so far
ok
Afraid not- not enough cooling power. CPU block is not great for quads either.
Anyway here’s a shopping list, but others may have different suggestions and you should really check out the Watercooling Sticky too! Obviously I can’t give you links to components OcUK don’t sell ;)
CPU Block DTek Fuzion Revision 2 (hard to find- only on preorder from OcUK)
GPU blocks – the one’s I said or the XSPC ones which are cheaper. From OcUK
Pump- XSPC DDC 10w Pro Pump/Reservoir. From OcUK
I don’t know your case so hard to tell what radiators you can fit in. Ideally 2 Thermochill 120.2s in series. From OcUK
If you get those radiators you will need 4 fans. Big discussions about which is best. I use Scythe S-Flex E, but Yate Loon 120mm Yate Loon D12SL-12 are very popular
Then you will need tubing (Masterkleer 7/16" Tubing- how much depends on your case and routing), distilled or deionised water, corrosion inhibitor, tubing clips (probably these- XSPC Tubing Clip For 3/8"), and ½” barbs for the radiators, pump and CPU block
Where's Cob gone ;) He usually participates in the same threads on W/Cooling
as I do, and mostly we agree:)
Don't buy a kit. IMO you will need 2 loops as watercooling your graphics cards will probably yield the most noticeable difference. I'm in the process of going water and i decided to start with a decent case. This will make setup easiler and will be better in the long run.
What case do you have?
a antec soho file server case, but i dont mind looking for another case. cheers for all your help guys i am getting there almost but any input you guys have please let me know.
thanks
