Water cooling loop components
2 Jan 2010
Firstly hey everyone, i've read these boards for quite a while but never posted..
I want to build a water cooling loop into my newly upgraded pc, but im not sure which parts to get. I've looked around at reviews etc but havent found many up to date or parts in the UK. My case hasnt got room for a 240mm rad, but i could put two 120mm rads sequentiality or would using a cpu block with two outlets to go to two 120mm rads the back to the resivoir be better? I have two iceQ 6950's which i wont put into the loop.
tl;dr
Im looking for;
CPU Block
Radiator/s
Pump
Resivoir
and the smaller tubing 3/8's?
Cheers.
Cheers for the quick reply mate. Budget is a max of £300 or pretty damn close. That spec looks good, did you see my edit ref. a waterblock with 2 outputs? Would that make any real difference?
The CPU block has one outlet and one inlet. That's the best way to do it. Not sure what you mean :confused:
Thats smaller tubing right?:confused:
yes. the 3/8 in the second spec is smaller
Would i be able to run this loop with just one of the rads? Its for an overclocked i5 2500k.
yes, but i would just use both. Te extra rad won't hurt and will keep your temps low enough when the 120 rad may be pushing it a little depending on the volts used and the OC
Also would 1L of fluid be enough?
yes, but you may aswell buy 2:p
The fans and the liquid are just a placeholder, don't know what colour you wanted.
Cheers for the spec. I dont need fans as i have enough spares and im thinking the pastel blue would be the best colour. The algae killer is sold out :( will look elseware for it.
How do you export these lists from Your Basket?
OcUK shopping basket pp for chrome
Use mayhems biocide :)
The pump in my spec is significantly better than the horrid EK one. If you can afford it, go for it :p
Excuse me :( I love my pump, it does the same job as your one but yours is significantly dearer. Why so much on a pump?
Okay, can you see any probs with this setup? I play on adding two grfx blocks at some point, so need the extra give in the loop for that.
YOUR BASKET
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
1 x EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
2 x Hardware Labs Black ICE Radiator SR1 120 - Black £44.99 (£89.98)
1 x EK Multioption Reservoir X2 150 Advanced £33.98
1 x Mayhems Pastel - Raspberry Purple Coolant 1L £14.99
1 x Masterkleer Hose Pack PVC 16/10mm (3/8ID) Clear 3.3m £10.88
1 x Mayhems Biocide 10ml £5.99
10 x EK PSC Compression Fitting 10mm 3/8" - G1/4 - Nickel - [Ideal for EK Kits] £2.75 (£27.50)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.30
Total : £338.57 (includes shipping : £10.00).
