I was thinking i can use a scalpel.. Is that a no?
So much easier with the cutters.
Can be done but:
£8.50 easier? lol.
Here's one with 3/8 tubing and fittings:
YOUR BASKET
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
1 x EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
2 x Phobya G-Changer 120 Ver. 1.2 Black £33.98 (£67.96)
1 x Alphacool Cape Corp Coolplex Pro 10 LT £16.99
2 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £14.99 (£29.98)
1 x Masterkleer Hose Pack PVC 16/10mm (3/8ID) Clear 3.3m £10.88
1 x OcUK Tube Cutter Aluminum 3-14mm £8.50
2 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.68 (£9.36)
10 x EK PSC Compression Fitting 10mm 3/8" - G1/4 - Nickel - [Ideal for EK Kits] £2.75 (£27.50)
Total : £325.13 (includes shipping : £10.00).
Soo, those fittings don't fit the tube...![]()
yes they do!
nope, have it in my lap and its too big..
They don't, the fittings has 5/8" OD & the tubing has 1/2" OD.
